[GRASS5] [bug #1066] (grass) strange r.reclass warning
Glynn Clements
glynn.clements at virgin.net
Tue May 28 18:07:28 EDT 2002
Request Tracker wrote:
> Subject: strange r.reclass warning
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> Dear developers,
> the r.reclass command prints a strange message:
> r.reclass in=riserve2001 out=tberiserve < reclassfile
> WARNING: Unable to create dependency file in [riserve2001 in
> habitatCap2001]
> The reclassfile looks like this:
> 164 45 49 28 78 34 171 = 1 caprioli campionati negativi
> 213 206 152 182 = 2 solo caprioli campionati positivi
> 6 65 57 15 = 3 solo casi umani
> 185 83 192 = 4 casi umani e caprioli campionati positivi
> The original map is not in the current mapset and belongs to a different owner.
> r.info riserve2001
> | Layer: riserve2001 Date: Thu May 31 15:42:47 2001 | Mapset: habitatCap2001 Login of Creator: lpotrich | Location: pat | DataBase: /mpa_gdata/ssi/BIO/GRASS_DATA/data
> g.gisenv
> GISDBASE=/mpa_gdata/ssi/BIO/GRASS_DATA/data
> LOCATION_NAME=pat
> MAPSET=adonini
> Perhaps the reclass_to file cannot be written?
Correct.
BTW, this was the very first change I made to GRASS (bug #229, March
2001). Before that, r.reclass would just fail if you didn't have write
permission on the source mapset.
> The current warning is not really helpful...
src/libes/gis/reclass.c, line 261:
G_warning (_("Unable to create dependency file in [%s in %s]"),
buf2, reclass->mapset);
Feel free to change it; although I'm not sure that any message will be
helpful to a user that doesn't understand the details of the reclass
mechanism. Maybe the situation should be silently ignored?
Glynn Clements <glynn.clements at virgin.net>
