[GRASS5] problems with [rsv].proj
Markus Neteler
neteler at itc.it
Fri May 31 03:09:09 EDT 2002
On Thu, May 30, 2002 at 03:16:31PM -0400, rgrmill wrote:
> GRASS5.0.0 probably should support datum changes other than nad27<->nad83.
> That is a very fundamental capability.
Apart from the discussion when to submit datum support: I agree that
GRASS should *as soon as possible* (whatever that means) support
Find attached an ongoing small test with northern Italian sample
coordinates. The datum support already present in PROJ4 improves
the result significantly (from 25m E-W and 70m N-S shifts to 2m E-W
and 9m N-S using the cs2cs program with datum).
Find attached preliminary results. I'll post the complete results later
in PROJ4 mailing list after receiving more known points for other
parts of Italy (is anyone there who can deliver this?).
Cheers
Markus
Reprojections of sample points with and without datum transformation
using 'proj', 'cs2cs' and a local special formula
Command lines:
cs2cs -v +proj=latlong +datum=WGS84 +to +init=epsg:26591 +towgs84=-225,-65,9
proj +proj=tmerc +lat_0=0.0 +lon_0=9.0 +k=0.999600 +x_0=1500000.0 +y_0=0.0\
+ellps=intl +units=m
Legend:
O: - The Lat/Long WGS84 coordinates have been obtained by GPS
- Gauss Boaga are official cadastrial control points
- The UTM WGS84 coordinates have been obtained by GPS (only for F:)
C: 'cs2cs' results with datum transformation (parameters see above)
P: 'proj' results without datum transformation (parameters see above)
F: Special spreadsheet formula (see below R code [1]), which converts from
UTM to Gauss-Boaga
Table with 3 sample points:
Lat/Long (WGS84) - MONTE CIMIMIRLO | Gauss Boaga (Roma40, Intl ellps)
O: 11 9 45.24184 46 4 13.11961 532.137 | 1667267.98 5104156.11 n/a
C: 11d9'45.24184E 46d4'13.11961N 532.137 | 1667269.19 5104147.45 483.851
P: " " - | 1667246.73 5104229.82 -
F: [official UTM: 667238.924 5104133.123] | 1667268 5104156 -
Lat/Long (WGS84) - MARTIGNANO | Gauss Boaga (Roma40, Intl ellps)
O: 11 7 58.87328 46 5 8.89033 429.782 | 1664936.81 5105815.65 n/a
C: 11d7'58.87328E 46d5'8.89033 429.782 | 1664938.08 5105806.98 381.467
P: " " - | 1664915.53 5105889.39 -
F: [official UTM: 664907.822 5105792.645] | 1664937 5105816 -
Lat/Long (WGS84) - [2] see below | Gauss Boaga (Roma40, Intl ellps)
O: 11 07 20.625264 46 04 20.726853 263.1778|1664154.8358 5104306.7929 213.0876
C: 11d07'20.625264E 46d04'20.726853N 263.1778|1664156.37 5104298.53 214.879
P: - | -
F: - | -
[1] Formula for Northern Italy, Fuso Ovest: UTM -> Gauss-Boaga
[From "bolletino BZ", here as R code]
NUTM <- 5104133.123
EUTM <- 667238.924
#NUTM <- 5105792.645
#EUTM <- 664907.822
a1 <- 1.00001586139729
b1 <- 0.00000816953815234324
a2 <- 1.00001587189443
b2 <- -0.00000816372109252845
P <- -63.43479941
Q <- 1000060.11675565
Ngb <- P + NUTM*a1 + EUTM*b1
Egb <- Q + EUTM*a2 + NUTM*b2
Egb
Ngb
[2] coordinates of the GPS permanent station of the PAT (servizio geologico)
