[GRASS5] [bug #1077] (grass) i.vpoints display bug in target window
    Request Tracker
    grass-bugs at intevation.de
    Fri May 31 12:34:02 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1077
Even the latest version of i.vpoints has some problems with
loading raster/vector maps and zooming (both for target
location). While I could fix several menu bugs this seems
to be related to the R_...() functions.
i.vpoints prints:
warp_map : duplicate name
which is from libraster.
Test:
- generate a image group
- start i.vpoints
- load source raster map (left), working
- load target reference raster map (right), working
- load target reference vector map, somewhat working, but raster map
  disappears
- zoom function for target window right: vector is re-displayed but
  not the raster map. Above warning appears.
I assume that this results from a single bug in handling the PAD
list - just guessing.
Hopefully someone can look into this.
 Markus
--- Headers Follow ---
>From neteler at itc.it  Fri May 31 18:34:01 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id D8B5C13922
	for <grass-bugs at lists.intevation.de>; Fri, 31 May 2002 18:34:00 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by mail.intevation.de (Postfix) with ESMTP id 840E71B6D6
	for <grass-bugs at intevation.de>; Fri, 31 May 2002 18:33:59 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g4VGXsn16897
	for <grass-bugs at intevation.de>; Fri, 31 May 2002 18:33:54 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g4VGXsK10178
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id g4VGXsm21038
	for grass-bugs at intevation.de; Fri, 31 May 2002 18:33:54 +0200
Date: Fri, 31 May 2002 18:33:54 +0200
To: grass-bugs at intevation.de
Subject: i.vpoints display bug in target window
Message-ID: <20020531183354.A21034 at itc.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5.1i
X-Spam-Status: No, hits=0.0 required=5.0 tests= version=2.20
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
