[GRASS5] GRASS 5.1 with shared libs problems
Markus Neteler neteler at itc.it
Sat Nov 2 11:17:55 EST 2002
trying to compile GRASS 5.1 (today's CVS version) with shared libs fails
for a few modules. Maybe some Makefile experts could look into this?
(Please run 'make clean' after 'cvs up -dP' due to updated links to 5.0
source code)
To activate shared libs, change two files:
include/Make/Lib.make
 -> at bottom: comment stlib, uncomment shlib
include/Make/Grass.make
 -> at top: switch LIB_PREFIX and LIB_SUFFIX settings
I also tried to apply the LIBRULE line for shared libs as found in 5.0's
mk/mid.mk
without success.
Thanks in advance for help,
 Markus
