[GRASS5] [bug #1389] (grass) v.cutregion.sh: resultant vector file(s) Comments are garbage
Markus Neteler
neteler at itc.it
Mon Nov 4 04:47:01 EST 2002
On Fri, Nov 01, 2002 at 12:22:11AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1389
> Subject: v.cutregion.sh: resultant vector file(s) Comments are garbage
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.0.0 (August 2002)
> When using v.cutregion.sh, the resultant vector file, and region boundary area-vector (if saved) contain the same garbage in the vector Comments field.
> Original line vector file imported with v.in.shape has no comment.
> Should it grab Original Scale from the input vector as well?
> eg:
> v.cutregion.sh input=coastline output=milf_coastln -s -r
> v.info milf_coastln
> | taß<øÿ¿05@ø@05@ |
Thanks for reporting.
There was "OTHER INFO" missing in the header contruction part of
v.cutregion.sh.
Fixed in CVS.
Markus
