[GRASS5] big ugly $HOME/GIS_ERROR_LOG
Dan Jacobson
jidanni at dman.ddts.net
Mon Nov 4 19:13:32 EST 2002
>> >> P.S. in tips_and_tricks.html: "To avoid sending error messages by
>> >> email, generate an empty file called GIS_ERROR_LOG in your home
>> >> directory"
>> >> Well, tell users how to use a different name if they want to, instead
>> >> of having such a big ugly file name in their home directory.
M> AFAIK you can use any filename (eg .rubbish) - untested.
M> Sorry, of course you cannot.
>> well, is there a variable involved? how can it tell which file, etc....
M> Look here:
M> src/libes/gis/error.c
OK:
* Gives the message, msg, to the user. Also print a message to
* $GISBASE/GIS_ERROR_LOG if the file exists and is writeable;
* and to the file $HOME in the users home directory if $HOME is set.
^^^ Shouldn't it say "that file in $HOME" ?!
M> Perhaps this should be changed to a variable
M> GIS_ERROR_LOG_FILE
M> but that's an issue for the developers ML.
OK, I sent this there.
