[GRASS5] Re: GRASS 5.1 build system
Radim Blazek blazek at itc.it
Thu Nov 7 03:08:39 EST 2002
On Wednesday 06 November 2002 08:14 pm, Glynn Clements wrote:
> Option 1 has the disadvantage of not supporting out-of-place builds.
> If you just want to compile and install GRASS, this isn't a problem.
> However, it is useful for development (e.g. allowing you to keep
> multiple build trees around), or for large sites (where you may wish
> to build GRASS on multiple systems from a single shared source tree).
But compile more platforms in the same source tree at the same time
each in its $(ARCH) dirs should be possible?
Do you mean multiple systems with identical $(ARCH) but other differences
like versions of libraries?
Radim
