[GRASS5] (no subject)
Eric G. Miller
egm2 at jps.net
Sun Nov 17 19:02:57 EST 2002
On Sun, Nov 17, 2002 at 02:07:21PM +0000, Glynn Clements wrote:
> Alex Shevlakov wrote:
> > there have been a certain number of messages like
> > this(:(
> > due to the fact that two needed include files are
> > not in one catalog, you have to configure
> > with option
> > --with-postgres-includes='/usr/local/pgsql/include
> > /usr/local/pgsql/include/internal'.
> I'm becoming more convinced by the day that g.column.pg should have
> the use of VARHDRSZ replaced by the literal constant 4, thereby
> eliminating the dependency upon postgres[_fe].h (which are internal
> headers; you shouldn't need to use them unless you're writing server
> extensions).
If that's the only use of VARHDRSZ, then I think I'd agree with you
about just using the magic number '4'. It's too bad PostgreSQL
doesn't provide an easier mechanism for getting at the definitions
of tables.
static const char signature[] =
"Copyright (c) 2002 Eric G. Miller <egm2 at jps.net>";
