[GRASS5] MySQL and PostgreSQL DBMI drivers for GRASS 5.1
Glynn Clements glynn.clements at virgin.net
Sat Nov 23 06:33:24 EST 2002
Markus Neteler wrote:
> > written and uploaded at the CVS are two new DBMI drivers,
> > one for PostgreSQL and one for MySQL. To compile them one needs grass51
> > and 'libpq' or 'libmysqlclient', respectively.
> > The code is at grass51/db/drivers catalog.
> Glynn, may I ask you to add a test to 'configure[.in]' for the mysql
> libs and include directories?
What should it be testing for?
What is the header called, what is the library called, which other
libraries (or sets of libraries) might be required, and which function
should configure expect to find in that library?
Glynn Clements <glynn.clements at virgin.net>
