[GRASS5] MySQL and PostgreSQL DBMI drivers for GRASS 5.1
Markus Neteler neteler at itc.it
Sat Nov 23 14:27:35 EST 2002
On Sat, Nov 23, 2002 at 06:09:20PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > > written and uploaded at the CVS are two new DBMI drivers,
> > > > > one for PostgreSQL and one for MySQL. To compile them one needs grass51
> > > > > and 'libpq' or 'libmysqlclient', respectively.
> > > > > The code is at grass51/db/drivers catalog.
> > > > Glynn, may I ask you to add a test to 'configure[.in]' for the mysql
> > > > libs and include directories?
> > > What should it be testing for?
> > > What is the header called, what is the library called, which other
> > > libraries (or sets of libraries) might be required, and which function
> > > should configure expect to find in that library?
> > According to
> >  grass51/db/drivers/mysql/Makefile
> > and
> >  grass51/db/drivers/mysql/globals.h
> > it needs
> > -L/usr/local/lib/mysql
> > -lmysqlclient
> > and
> > #include <mysql/mysql.h>
> That's 2 out of 4; I still need to know a symbol which will be present
> in libmysqlclient, and which libraries libmysqlclient might depend
> upon.
> I'll take a guess at mysql_query() being defined in libmysqlclient (it
> is referenced in db/drivers/mysql, but doesn't appear to be defined
> anywhere), and I'll assume that no other libraries need to be
> specified.
Probably Alex can help. I just tried it:
checking for mysql_query in -lmysqlclient... no
configure: error: *** Unable to locate MySQL library.
thuille:grass51[273.17] locate libmysqlclient
/usr/lib/mysql/libmysqlclient.so.10
/usr/lib/mysql/libmysqlclient.so.10.0.0
/usr/lib/mysql/libmysqlclient.a
/usr/lib/mysql/libmysqlclient.so.9
/usr/lib/mysql/libmysqlclient.so.9.0.0
thuille:grass51[274.18] nm /usr/lib/mysql/libmysqlclient.so | grep
mysql_query
0000a210 T mysql_query
cat config.log
configure:9326: checking whether to use MySQL
configure:9346: checking for location of MySQL includes
configure:9372: checking for mysql/mysql.h
configure:9380: gcc -E   conftest.c >/dev/null 2>conftest.out
configure:9418: checking for location of MySQL library
configure:9443: checking for mysql_query in -lmysqlclient
configure:9460: gcc -o conftest -g -O2     conftest.c -lmysqlclient   1>&5
/usr/bin/ld: cannot find -lmysqlclient
collect2: ld returned 1 exit status
configure: failed program was:
#line 9449 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error.  */
/* We use char because int might match the return type of a gcc2
    builtin and then its argument prototype would still apply.  */
char mysql_query();
int main() {
mysql_query()
; return 0; }
Probably the library is not found?
Markus
