[GRASS5] [bug #1436] (grass) r.mapcalc seems to treat [0,1] like [0,2]
Glynn Clements
glynn.clements at virgin.net
Sun Nov 24 07:14:13 EST 2002
Request Tracker wrote:
> Subject: r.mapcalc seems to treat [0,1] like [0,2]
Oops. Due to a missing break statement, the code shifts integer maps
twice, so the column offset is effectively doubled.
You can fix this manually, by adding a break statement at line 225 in
src/raster/r.mapcalc3/map.c (see the other two clauses for
comparison), or by applying the attached patch.
Glynn Clements <glynn.clements at virgin.net>
--- src/raster/r.mapcalc3/map.c~ Thu Oct 10 20:12:24 2002
+++ src/raster/r.mapcalc3/map.c Sun Nov 24 12:10:58 2002
@@ -222,6 +222,7 @@
for ( ; i < columns; i++)
SET_NULL_C(&ibuf[i]);
+ break;
case FCELL_TYPE:
for (i = 0; i < columns - col; i++)
