[GRASS5] MySQL and PostgreSQL DBMI drivers for GRASS 5.1
Markus Neteler neteler at itc.it
Sun Nov 24 13:38:09 EST 2002
On Sat, Nov 23, 2002 at 11:07:58PM +0000, Glynn Clements wrote:
> > thuille:grass51[273.17] locate libmysqlclient
> > /usr/lib/mysql/libmysqlclient.so.10
> > /usr/lib/mysql/libmysqlclient.so.10.0.0
> > /usr/lib/mysql/libmysqlclient.a
> > /usr/lib/mysql/libmysqlclient.so.9
> > /usr/lib/mysql/libmysqlclient.so.9.0.0
> Then you will need --with-mysql-libs=/usr/lib/mysql
great, this did the trick.
> > thuille:grass51[274.18] nm /usr/lib/mysql/libmysqlclient.so | grep
> > mysql_query
> > 0000a210 T mysql_query
> OK, so that's probably the right symbol to be checking for.
Yep. Now the driver get's compiled, if present.
Thanks to Alex and Glynn,
 Markus
