[GRASS5] Re: [GRASSLIST:5080] Re: r3out.v5d(?) problem
Markus Neteler
neteler at itc.it
Wed Nov 27 03:11:20 EST 2002
On Tue, Nov 26, 2002 at 03:08:14PM -0800, John Harrop wrote:
> Markus, Eric and Jaro:
> I moved this thread to the dev list since it seems to be heading that
> way ;-)
yep.
> Thanks for your responses. Our group is most interested in the 3D
> volumetric and vector support and since we need to test for internally
> written code I think we can probably help with testing. I'll take a
> look at the current CVS and re-read the programmers manual. I've been
> looking at source navigator and considering using it - anyone else
> tried it or have other comments?
> Is the row-col problem specifically described anywhere? Or is it just
> as fast to browse the source?
You find problems described here:
src.contrib/GMSL/g3d/src3d/BUGS
(or
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src.contrib/GMSL/g3d/src3d/BUGS?rev=1.7&content-type=text/vnd.viewcvs-markup
Implementation ideas as well as comments from the original developers
are here:
src/libes/g3d/doc/
(or
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/libes/g3d/doc
In a second mail I'll forward the latest (two month ago) fixes from
Alfonso Vitti.
Markus
> Markus Neteler wrote:
> >Hi John,
> >the CVS code of GRASS 5.0.1 (to be released hopefully soon) contains
> >some fixes for the G3D from Alfonso Vitti (Univ. Trento) which
> >overcome a set of problems. AFAIK there is still a problem with
> >rows and cols not equal.
> >If you are able to compile GRASS 5.0.0, you may try the CVS version
> >or CVS snapshot. We definitly need 1 or 2 people to look again into
> >G3D and test the modules.
> >Best regards
> > Markus Neteler
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
