[GRASS5] GRASS and lat/long with sphere
Markus Neteler
neteler at itc.it
Thu Oct 3 11:40:06 EDT 2002
On Tue, Oct 01, 2002 at 02:31:31PM +0100, Glynn Clements wrote:
> > May I ask you to apply the change? As far as I understand it should
> > only users of "sphere" ellipsoid. So it is no severe change (I have
> > already another tester in mind, hi Alessandro F.!).
> Done.
Thanks, Glynn!
> The following programs all contain direct references to functions
> whose names contain the words "ellipsoid" or "spheroid", and so are
> prime candidates for testing.
> etc/bin/cmd:
> d.geodesic
yes, is calculating the distance (unfortunately only in miles)
> d.where
yes (compared to g.region -c).
[ but d.where -d
EAST: NORTH:
-121239.87944942 7554345.52279129
doesn't work in a UTM location!!]
> m.datum.shift
> m.gc2ll
> m.ll2gc
> m.ll2u
> m.region.ll
> m.tiger.region
> m.u2ll
... all untested.
> r.buffer
yes.
> r.in.ll
> r.in.utm
... both untested.
> r.surf.idw
yes.
> v.apply.census
> v.in.tig.basic
> v.in.tig.lndmk
> v.out.sdts
... all untested.
> etc/bin/inter:
> g.setproj
yes.
> m.proj
no in terms of 'sphere': it doesn't ask for ellipsoid when defining 'll'
> m.proj2
Unclear to me:
I tried to convert Botswana coordinates with:
m.proj2 inproj="proj=utm,name=utm,ellps=wgs84,zone=35,unfact=1.0" \
outproj="proj=ll,ellps=wgs84,south" input=utm.coord output=new.ll.coord
In file 'utm.coord' I stored the UTM South coordinates:
255016.575000 7519449.975000
It prints:
Using in proj: +proj=utm +proj=utm +name=utm +a=6378137.0000000000
+es=0.0066943800 +zone=35 +unfact=1.0
Using out proj: +proj=ll +proj=ll +a=6378137.0000000000 +es=0.0066943800
+south
21:12:38.829844E 67:41:13.81965N
Expected result is (ellips = wgs84):
24:37:10.851726E [24.61968]
22:20:21.876491S [-22.33941]
Using 'sphere' I get
which is the same nonsense.
A general problem is that m.proj2 happily calculates coordinates even
if the specified keywords are mistyped :-(
Another test with Gauss-Boaga, Italy coordinates:
GRASS:~ > g.region -c
region center northing: 5173900.000000
region center easting: 1697080.000000
GRASS:~ > g.region -l
Center Longitude: 11:34:34.913698E [11.57636]
Center latitude: 46:40:48.785419N [46.68022]
m.proj2
inproj="proj=tmerc,name=tmerc,ellps=international,x_0=1500000,k_0=0.9996,lon_0=9.0" \
outproj="proj=ll,ellps=wgs84" input=gk.coor output=new.ll.coord2
Result with wgs84 ellipsoid
11:34:38.225903E 46:41:19.429087N
Result with sphere 'ellipsoid' (changed in above cmd line):
Oops. Identical.
So that doesn't seem to work properly (how many bugs here in m.proj2?).
Perhaps some more people could check m.proj2 functionality.
> The functions in question are:
> CC_get_spheroid
> CC_spheroid_name
> CC_u2ll_spheroid
> CC_u2ll_spheroid_parameters
> G_ellipsoid_name
> G_get_ellipsoid_by_name
> G_get_ellipsoid_parameters
> G_get_spheroid_by_name
Mhhh. Probably ok. The problems mentioned above seem to be only related to
module implementations.
But: I did another test with vector data:
- vector lines map
- imported into ll/sphere location
- imported into ll/wgs84 location
- re-projected from ll/sphere location to UTM/wgs84 location
- re-projected from ll/wgs84 location to UTM/wgs84 location
Compared in UTM/wgs84 location both maps are identically geocoded
although a different ellipsoid/sphere was specified. This looks
strange to me.
So far my tests,
Markus
