[GRASS5] Portability issues
    Eric G. Miller
    egm2 at jps.net
    Thu Oct  3 23:00:25 EDT 2002
On Thu, Oct 03, 2002 at 04:51:37PM +0100, Glynn Clements wrote:
[snip]
> Some of these could simply be replaced with ANSI functions, while
> others suggest that new functions should be added to e.g. libgis to
> improve portability.
> Some comments on specific functions:
> + open close creat read write lseek truncate
> Many of these could probably be replaced with the ANSI stdio
> equivalents.
libgis uses file descriptors heavily, so POSIX functions are
useful/mandatory. ANSI doesn't have a truncate() or ftruncate().
> + mkdir chdir opendir closedir readdir
> The ANSI libraries don't deal with directories. However, any system on
> which GRASS runs will have equivalent functionality; we just need to
> provide a portable interface.
Not a bad idea to have system interface (though Winders supposedly is
supporting POSIX these days...).
> + drand48 lrand48 srand48
> These can be replaced with rand/srand. Presently, all programs which
> use (s.random, r.random, r.mapcalc) them can fall back to rand/srand,
> but [rs].random attempt to guess whether the *rand48 functions are
> available based upon platform macros rather than HAVE_DRAND48.
Might be good to include a couple random number generators in libgis.
Sources for a number of good ones are freely available..
> + snprintf
> C9X defines this, so in a couple of decades it won't be a problem. For
> now, a wide variety of solutions are possible, all with their own
> advantages and disadvantages.
Couple of *decades*! ;^) I think mostly we'd rather have an asprintf()
available...
> + sigaction sigemptyset
> Only used by r.mapcalc. signal() can be used instead, although
> signal() has problems of its own (BSD-vs-SysV signal semantics,
> general lack of flexibility).
sigaction is POSIX, so should be fairly portable by now.  ANSI only
minimally describes signals, hence the BSD vs. SysV, etc...
[snip]
> + putenv
> Used by XDRIVER; it probably doesn't need to be portable.
Why not setenv()?
[snip]
> + gethostname
> Used by G__machine_name(), which is sensible enough. Presumably
> equivalent functionality is available on any networked system (and, on
> non-networked systems, you don't really need a per-machine
> identifier).
That's mostly for the tmpfile thing these days, no?  Probably could
think about getting rid of it if the whole mapset permissions thing
is redone.. (Hmm, there's also that email interface...).
begin 664 .signature
M<F5L;&E-("Y'(&-I<D4@/G1E;BYS<&I`,FUG93P)"`@("`@("`@("`@("`@(
M"`@("`@("`@("`@("`@("`A%<FEC($<N($UI;&QE<B`\96=M,D!J<',N;F5T
"/@H`
end
