[GRASS5] [bug #1338] (grass) r.mapcalc results contain no data
Request Tracker grass-bugs at intevation.de
Mon Oct 7 23:52:24 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1338
Subject: r.mapcalc results contain no data
Platform: WindowsNT/2000/XP
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.0pre3
I'm following the tutorial from "GRASS Seeds" at http://www.geog.le.ac.uk/assist/grass/seeds/.
The data set "leics" is also from there.
When using r.mapcalc to get a new layer from two complementary layers, the result contains no data, whether interactively or  non-interactively.
GRASS:~ >r.mapcalc asp_cost=asp_north+asp_south
EXECUTING asp_cost = ...  100%
CREATING SUPPORT FILES FOR asp_cost
GRASS:~ >r.report asp_cost units=percent
|                        Category Information                          |   %  |
|#|description                                                         | cover|
|*|no data. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .|100.00|
GRASS:~ >r.report asp_north units=percent
|1|0 thru 180 . . . . . . . . . . . . . . . . . . . . . . . . . . . . .| 51.35|
|*|no data. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .| 48.65|
GRASS:~ >r.report asp_south units=percent
|10|181 thru 360 . . . . . . . . . . . . . . . . . . . . . . . . . . . | 45.34|
| *|no data. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 54.66|
In fact, the problem also occurs with grass5 on my redhat 7.3 platform, which I downloaded binaries just a few days ago from  a mirror site.
Forgive my poor English.
Thanks,
Zhao Jianwei
-------------------------------------------- Managed by Request Tracker
