[GRASS5] CVS maintenance
Bernhard Reiter
bernhard at intevation.de
Tue Oct 8 15:45:25 EDT 2002
CVS is up again.
There is a modern openssh daemon running now.
This mean: Now we can also use ssh2 keys.
For new keys version 2 is preferred.
If you see permission denied errors now, you should,
Try adding the "-1" protocol flag to ssh or in the ssh2402 script,
if you have a modern openssh and a version 2 key around
but want to use the version 1 key.
On Tue, Oct 08, 2002 at 08:36:32PM +0200, Bernhard Reiter wrote:
> You might encounter difficulties with the write access
> of the CVS in the next half hour as I'm improving it. :)
Professional Service for Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021008/ac589d38/attachment.bin
