[GRASS5] Grass 5.0.0 Mac OS 10.2 Report
Jeshua Lacock
jeshua at OpenOSX.com
Tue Oct 8 23:26:14 EDT 2002
Greetings,
Here is my full report of my attempt to get the failed modules compiled
on Mac OS X 10.2.1 (Jaguar, Darwin 6.0) using gcc 3.1.
With booth d.zoom and i.pca I renamed the "round" function to "round2"
because it conflicted with the "round" function included with of the
Mac OS X math library. Both modules test out OK.
The module g.region fails with E_edit_cellhd as an undefined symbol.
The v.reclass, r.weight and r.reclass modules all fail with
_E_edit_cats as an undefined symbol.
While building "src/raster/r.support", in addition to missing
_E_edit_cats, I get another undefined symbol:
/usr/bin/ld: Undefined symbols:
_E_edit_cats
_E_edit_fp_cats
E_edit_cellhd, E_edit_cats and E_edit_fp_cats are all defined in
src/include/edit.h. Suspicious?
While attempting to build r.in.gdal I get some strange undefined
symbols:
_GBGetSymbol
___gxx_personality_v0
__Unwind_Resume
__ZdlPv
__Znwm
__ZTVN10__cxxabiv117__class_type_infoE
__ZTVN10__cxxabiv120__si_class_type_infoE
___cxa_pure_virtual
__ZdaPv
__Znam
A google search indicated that this could be a symptom of using cc
instead of c++, so I used g++ instead of gcc and just get:
_GBGetSymbol
The last failed module is NVIZ2.2:
In file included from nvizAppInit.c:9:
interface.h:257: conflicting types for `Tk_SetAppName'
/usr/local/include/tkDecls.h:573: previous declaration of
`Tk_SetAppName'
make[1]: *** [OBJ.powerpc-apple-darwin6.0/nvizAppInit.o] Error 1
make: *** [nvwish] Error 2
So I commented out "char *Tk_SetAppName(Tk_Window, char *);" from
interface.h and I got:
togl.c:161: header file 'tkInt8.4.h' not found
So I tried copying tkInt.h to tkInt8.4.h
It then built with some warnings:
init_commands.c: In function `init_commands':
init_commands.c:131: warning: passing arg 3 of `Tcl_CreateCommand' from
incompatible pointer type
init_commands.c: ....
....for all lines that use "Tcl_CreateCommand"
nviz_init.c: In function `Ngetargs':
nviz_init.c:303: warning: assignment discards qualifiers from pointer
target type
nviz_init.c:304: warning: assignment discards qualifiers from pointer
target type
[...snip...]
togl.c: In function `Togl_Init':
togl.c:729: warning: passing arg 3 of `Tcl_CreateCommand' from
togl.c: In function `Togl_Cmd':
togl.c:1179: warning: passing arg 3 of `Tcl_CreateCommand' from
[...snip...]
/usr/bin/ld: warning multiple definitions of symbol _tclPlatStubsPtr
/usr/lib/libtcl.dylib(tclStubLib.o) definition of _tclPlatStubsPtr
/usr/local/lib/libtk8.4.dylib(tclStubLib.o) definition of
_tclPlatStubsPtr
/usr/bin/ld: warning multiple definitions of symbol _tclIntStubsPtr
/usr/lib/libtcl.dylib(tclStubLib.o) definition of _tclIntStubsPtr
_tclIntStubsPtr
/usr/bin/ld: warning multiple definitions of symbol _Tcl_InitStubs
/usr/lib/libtcl.dylib(tclStubLib.o) definition of _Tcl_InitStubs
/usr/local/lib/libtk8.4.dylib(tclStubLib.o) definition of _Tcl_InitStubs
/usr/bin/ld: warning multiple definitions of symbol _tclIntPlatStubsPtr
/usr/lib/libtcl.dylib(tclStubLib.o) definition of _tclIntPlatStubsPtr
_tclIntPlatStubsPtr
/usr/bin/ld: warning multiple definitions of symbol _tclStubsPtr
/usr/lib/libtcl.dylib(tclStubLib.o) definition of _tclStubsPtr
/usr/local/lib/libtk8.4.dylib(tclStubLib.o) definition of _tclStubsPtr
/usr/bin/ld: warning suggest use of -bind_at_load, as lazy binding may
result in errors or different symbols being used
symbol _tclIntPlatStubsPtr used from dynamic library
/usr/lib/libtcl.dylib(tclStubLib.o) not from earlier dynamic library
symbol _Tcl_InitStubs used from dynamic library
symbol _tclStubsPtr used from dynamic library
symbol _tclPlatStubsPtr used from dynamic library
When I attempt to run NVIZ I get:
GRASS 5.0.0 > nviz
child killed: SIGABRT
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ
>&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass5/bin/nviz" line 16)
So I tried:
GRASS 5.0.0 > eval exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/Init.sh: line 517: 20182 Abort trap
$ETC/run $SHELL
Cleaning up temporary files.....
done
Goodbye from GRASS GIS
[themac:~] jeshua%
And it quits me right out of Grass!
Everything else seems to work great - excellent work!
Any help would be greatly appreciated! I am willing to hire someone to
log-on and take a look...
Thanks,
Jeshua Lacock __________________________
Programmer/Owner Phone: 760.935.4736
http://OpenOSX.com Fax: 760.935.4845
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
