[GRASS5] current release branch
Bernhard Reiter
bernhard at intevation.de
Thu Oct 10 09:42:07 EDT 2002
On Wed, Oct 09, 2002 at 07:03:40PM +0200, Radim Blazek wrote:
> what is the current release branch?
Thanks for Glynns explainations.
I'd like to add
that our original plan was
to now have a time period with open development on HEAD.
And then make a fresh branch with a fix critical bugs only freeze
for an upcoming 5.0.1 release.
The only strong reason to deviate from this plan would be
that we've found some _grave_ misstakes in the 5.0.0 release
and need to make a quick 5.0.1 release to only fix these _grave_
errors from the current (old) release branch.
Markus: What do you think?
So the original question strictly would be answered:
There is no active release branch for grass50,
because work should currently be done in HEAD.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021010/92d23a94/attachment.bin
