[GRASS5] Grass 5.0.0 Mac OS 10.2 Report
Markus Neteler neteler at itc.it
Fri Oct 11 03:53:30 EDT 2002
On Thu, Oct 10, 2002 at 05:08:56PM +0100, Glynn Clements wrote:
> AFAICT, the only robust solution is for all GRASS libraries to be
> named "libgrass_foo.a" rather than just "libfoo.a".
This may be a good idea in any case (also solves problems in case
the GRASS libs go somewhere into the system's standard lib directories).
Markus
