[GRASS5] NVIZ Compiling Error
Glynn Clements
glynn.clements at virgin.net
Fri Oct 11 14:42:57 EDT 2002
Otto Dassau wrote:
> - Compiling NVIZ from grass cvs (HEAD) snapshot from 04-Oct-2002 on my
> linux now works with Tcl/Tk 8.4 and gcc version 3.2 -> grazie Markus !
> but ...
> Using NVIZ another problem appeared. All! functions work, but I get
> error
> messages setting height, zexag and perspective:
> invalid command name "tkCancelRepeat"
> while executing
> "tkCancelRepeat"
> (command bound to event)
> Does anybody has a solution for this ?
tkCancelRepeat is a built-in command in Tcl/Tk 8.0 (and presumably up
to 8.3, as no-one else has reported this).
Unless we can determine that 8.4 has a replacement, we should define a
stub, e.g.
if {[string length [info commands tkCancelRepeat]]} {} {
proc tkCancelRepeat {} {}
Glynn Clements <glynn.clements at virgin.net>
