[GRASS5] Draft GRASS 5.1 documentation available now
Markus Neteler
neteler at itc.it
Mon Oct 21 03:19:10 EDT 2002
an updated version of the draft GRASS 5.1 programmer's manual
is available now here:
http://mpa.itc.it/markus/grass51/index.html
A new "modules" section is added which organizes the
Vect_*() functions by topic (open functions, close functions,
network functions etc).
To improve the function detection, I need some regex assistance for
'sed' (compare
grass51/lib/vector/Vlib/generate_dox.sh
). In general I grep all '\\fn' from all *.c files, then I want
to extract the function names:
So, how can I extract words starting with 'Vect_' and ending with either
space or '('? The current solution in above script is not error free.
Examples:
\fn int Vect_tin_get_z( struct Map_info *Map
-> Vect_tin_get_z
or
\fn struct line_cats *Vect_new_cats_struct ()
-> Vect_new_cats_struct
etc. Unfortunately I don't know REGEX enough to write a 'sed' instruction.
Thanks,
Markus
On Fri, Oct 18, 2002 at 07:23:27PM +0200, Markus Neteler wrote:
> Ciao Roberto and Radim,
> GRASS developers,
> the last days I have started to implement GRASS 5.1 documentation
> using doxygen. It is pretty easy :-) And we can generate
> - HTML,
> - Latex,
> - PDF
> (- XML, RTF etc)
> from the GRASS source. Basic idea is to add some commands into the
> source code which are then interpreted by 'doxygen'. An example:
> \fn int db_fetch (dbCursor *cursor, int position, int *more)
> \brief fetches something from somewhere
> \return 0 on success, -1 on error
> \param dbCursor, position in table, somethingelse
> int
> C code of function;
> (note the exclamation mark above which is needed)
> See for real world examples:
> grass51/lib/vector/Vlib/*
> grass51/lib/db/dbmi/* [only placeholders added]
> Overview pages can be easily written, see for example:
> grass51/lib/vector/vector_arch.dox
> which is now the "GRASS 5.1 Architecture" start page.
> The major advantages are
> - documenting in the source code (keeps things in sync)
> - no extra programmer's manual to write and update
> - possibility to auto-generate PDF manual by cronjob
> - doxygen is a maintained project (http://www.doxygen.org)
> To try GRASS-51-doc generation at home, enter (after updating from CVS):
> cd grass51/lib/vector/
> Now following commands are available:
> - Generate HTML document:
> make htmldocs
> - Generate Latex-DVI document (requires Latex):
> make latexdocs
> - Generate PDF document (requires Latex):
> make pdfdocs
> - Delete ./latex and ./html docs directories:
> make cleandocs
> Let me kindly invite everybody to use and extend the GRASS documentation.
> Roberto, you may also use it for DGLib...
> For advanced tricks (Latex formula etc) see the doxygen site.
> A today's PDF version is here:
> http://mpa.itc.it/markus/tmp/grass51_2002_10_18refman.pdf
> (520kb, please don't print as it will change)
> A today's HTML version is here:
> http://mpa.itc.it/markus/tmp/html/
> Of course everything can be nicer, but it is a starting point.
> Cheers
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
