[GRASS5] [bug #1367] (grass) d.mon manpage doesn't say how to get bigger monitors
Request Tracker grass-bugs at intevation.de
Tue Oct 22 17:47:43 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1367
Subject: d.mon manpage doesn't say how to get bigger monitors
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0pre1
the user should have a hint about where to learn how to make different sized monitors
right therer on the d.mon manpage.
Also man/man1/monitorcap.1
should be in a different section than(1), because 1 is for commands.
maybe 5.  then you can write SEE ALSO monitorcap(5)
-------------------------------------------- Managed by Request Tracker
