Why "libes"? (was Re: [GRASS5] gis lib: write error function (put_row.c))
Russell Senior
seniorr at aracnet.com
Wed Oct 23 04:36:50 EDT 2002
>>>>> "Markus" == Markus Neteler <neteler at itc.it> writes:
Markus> Hi, while having the problem that a disk run out of space
Markus> while using r.in.gdal, I found that
Markus> write_error() in src/libes/gis/put_row.c just contains
Markus> G_warning() and not G_fatal_error().
I know this may seem trivial, but why does grass use "libes" instead
of the more common "lib"? It seems gratuitously different. Is there
a reason for the difference? It "bothers" me aesthetically.
Russell Senior ``I've seen every kind of critter God ever made,
seniorr at aracnet.com and I ain't never seen a meaner, lower, more
stinkin' yellow hypocrite than you!''
-- Burl Ives as Rufus Hennessy
