[GRASS5] ps.map problem resolved
Michael Ash mash at econs.umass.edu
Thu Oct 24 14:04:09 EDT 2002
Radim's suggestion indeed resolved the problem.  From the
cygwin command line, I ran
tr -d '\015' < oldmapinstructions > newmapinstructions
and newmapinstructions ran with a problem as the input to ps.map
Thank you very much.
(I remain puzzled why the "size 1" line did NOT cause a
problem, only the "color red" line.)
Best,
Michael Ash
> > I am using GRASS 5.0pre3 on Cygwin/Windows
> > I gave ps.map the following mapping instruction file
> > sites censusbg
> >   color red
> >   size 1
> >   end
> > raster onsitegridlogscore
> > end
> > ps.map rejects the file with the following message:
> > PS-PAINT: using default configuration values.
> >  : illegal color request
> > If I remove the color instruction from the mapping
> > instruction file, then there is no complaint and the map is
> > produced (without the desired color).
> > If I give the instructions interactively, then there is no
> > complaint and the map is produced (with the desired color)
> It could be problem with line endings. If the file is written on
> windows, try to remove <CR> by "tr -d '\015'"
Michael Ash, Assistant Professor
  of Economics and Public Policy
Department of Economics and CPPA
University of Massachusetts
Amherst, MA 01003
Tel 413-545-6329 Fax 413-545-2921
Email mash at econs.umass.edu
http://www-unix.oit.umass.edu/~maash
