[GRASS5] debian compilation errors
Dan Jacobson jidanni at dman.ddts.net
Tue Oct 29 17:57:45 EST 2002
Dear grass developers, Markus says to post this here.
On Sun, Oct 27, 2002 at 05:42:29PM +0800, Dan Jacobson wrote:
> After a 110 minute modem download:
> checking whether to use Tcl/Tk... yes
> checking for location of Tcl/Tk includes...
> checking for tcl.h... no
> configure: error: *** Unable to locate Tcl includes.
> but
> $ locate /tcl.h
> /usr/include/tcl8.3/tcl.h
> I suppose I will wait for Fog to make the .deb
Please post this to the GRASS developers ML, there may be
an easy "trick".
 Markus
Subject: Re: 5.1 compilation errors
On Sun, Oct 27, 2002 at 04:50:47PM +0800, Dan Jacobson wrote:
> I did
> $ make clean distclean mixclean
> $"CFLAGS=\"-g -Wall\" ./configure
> --with-grass50=/home/jidanni/tmp/grass51/src/grass50_exp_2002_10_25
> --enable-opengl=no
> and still
> 	-o OBJ.i686-pc-linux-gnu/GS2.o -c GS2.c
> In file included from GS2.c:19:
> gstypes.h:15: GL/gl.h: No such file or directory
> GS2.c:24: GL/gl.h: No such file or directory
Please post this to the developer's ML.
Without ncurses package you cannot compile GRASS. Also
MEsa-devel package must be installed (gl.h).
Without ncurses the libedit won't compile, subsequently
many modules do not compile.
M.
In file included from edit_cats.c:32:
/home/jidanni/tmp/grass51/src/grass51_exp_2002_10_25/include/vask.h:2: curses.h: No such file or directory
make[2]: *** [OBJ.i686-pc-linux-gnu/edit_cats.o] Error 1
make[2]: Leaving directory `/home/jidanni/tmp/grass51/src/grass51_exp_2002_10_25/lib/edit'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/jidanni/tmp/grass51/src/grass51_exp_2002_10_25/lib'
make: *** [default] Error 1
make[2]: *** [OBJ.i686-pc-linux-gnu/GS2.o] Error 1
make[2]: Leaving directory `/home/jidanni/tmp/grass51/src/grass51_exp_2002_10_25/lib/ogsf'
earlier:
configure: In function `main':
configure:2637: structure has no member named `maxy'
configure: failed program was:
#line 2631 "configure"
#include "confdefs.h"
#include <curses.h>
  WINDOW w;
int main() {
w.maxy = 0;
; return 0; }
configure:2660: gcc -c -g -Wall  conftest.c 1>&5
http://jidanni.org/ Taiwan(04)25854780
