[GRASS5] Help: Need Assistance
Markus Neteler neteler at itc.it
Tue Sep 3 03:11:05 EDT 2002
On Tue, Sep 03, 2002 at 12:18:18PM +0530, BhuvanJ at riskinc.com wrote:
> Hi All,
> Facing a problem when performing orthorectification. I am performing all
> the 8 required steps properly.
> Below is a error description:
> GIS Error: error while writing in temp file. I found this error when grass
> notify me through mail in /var/spool/mail/root file.
> Any solution highly appreciated.
This error will be related to a "disk full" problem (I still vote
for meaningful error messages!).
When running orthorectification, GRASS internally generates at
least 1 temp-file in the mapset/.tmp/ directory. While
running the process, I suggest to run
watch df -h
in a second terminal window to find the partition which is
full (we have this problem here as well from time to time).
Note that leaving GRASS will cleanup this temp directory.
Only more space on hard drive or a reduced resolution will help.
Markus
