[GRASS5] grass5 on darwin - problem w/init
Crudeli
crudeli at mail.nauta.it
Tue Sep 10 05:39:24 EDT 2002
If you are using OSX 10.2 (Jaguar), you might be interested in the
following corrections to your autoconf file:
good luck,
RafDouglas CTC
____________________________
http://www.osxgnu.org/#jagbugs
In the file /usr/share/autoconf/autoconf.m4f line 7294 should read:
exit (setpgrp (0,0) == -1);])],
not
exit (setpgrp (1,1) == -1);])],
As a result any program using GNU configure may not compile (just
about all of them). You may wish to edit this file to reflect the
above changes
What has changed in 10.2?
The biggest changes seem to be that the System linked libraries in OS
X have moved to separate libraries so the LDFLAGS and CFLAGS have to
be set.
The most common new settings are:
CFLAGS=-no-cpp-precomp
LDFLAGS=-ltinfo -lgcc
( setenv CFLAGS -no-cpp-precomp;setenv LDFLAGS '-ltinfo -lgcc')
If a program did not use any of libraries that were moved it still
works on 10.2.
Example :bzip2, gnutar, rpm etc.
>hello all:
>i gave compiling grass5.0 a whirl today; this is my error.log:
RafDouglas Candidi Tommasi Crudeli
ct at ehleng.com
"To know, to will, to dare, to be silent."
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20020910/428351e9/attachment.html
