[GRASS5] grass5 on darwin - problem w/init
andy agena andya at mac.com
Tue Sep 10 09:23:14 EDT 2002
hello all:
i made the changes to autoconf.m4f below and started from scratch;
still have the "/sw/grass5/etc/Init.sh: /sw/grass5/etc/lock: No such
file or directory" error.  i've sent my make.log to Glynn, so we'll see
if there's anything there...
andy
Begin forwarded message:
> From: Crudeli <crudeli at mail.nauta.it>
> Date: Tue Sep 10, 2002  04:39:24 US/Central
> To: grass5 at grass.itc.it, andy agena <andya at mac.com>
> Subject: Re: [GRASS5] grass5 on darwin - problem w/init
> If you are using OSX 10.2 (Jaguar), you might be interested in the
> following corrections to your autoconf file:
> good luck,
> RafDouglas CTC
> ____________________________
> From:
> http://www.osxgnu.org/#jagbugs
> In the file /usr/share/autoconf/autoconf.m4f line 7294 should read:
> exit (setpgrp (0,0) == -1);])],
>        not
> exit (setpgrp (1,1) == -1);])],
> As a result any program using GNU configure may not compile (just
> about all of them). You may wish to edit this file to reflect the
> above changes
> What has changed in 10.2?
> The biggest changes seem to be that the System linked libraries in OS
> X have moved to separate libraries so the LDFLAGS and CFLAGS have to
> be set.
> The most common new settings are:
> CFLAGS=-no-cpp-precomp
> LDFLAGS=-ltinfo -lgcc
> ( setenv CFLAGS -no-cpp-precomp;setenv LDFLAGS '-ltinfo -lgcc')
> If a program did not use any of libraries that were moved it still
> works on 10.2.
> Example :bzip2, gnutar, rpm etc.
> hello all:
> i gave compiling grass5.0 a whirl today; this is my error.log:
> __________________________________________
> RafDouglas Candidi Tommasi Crudeli
> ct at ehleng.com
> "To know, to will, to dare, to be silent."
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020910/384fd855/attachment.bin
