[GRASS5] Re: pg grass darwin - working
andy agena andya at mac.com
Wed Sep 11 13:18:53 EDT 2002
Hi Glynn:
Well, I have PostgreSQL 7.2.2 running with GRASS, though I'm not really
sure why (well, I do need to add my grass user account to my postgresql
group to use it, but g.*.pg's are now in my bin--g.select.pg only
squawks about me not being part of the proper group).  I added the
quotes around postgres-includes two paths, but that's about it.
the only configure errors are:
Compilation error in module: src/libes/vect32/georef (ignored)
Compilation error in module: src/display/d.zoom (ignored)
Compilation error in module: src/imagery/i.pca (ignored)
Compilation error in module: src/raster/r.in.gdal (ignored)
Compilation error in module: src/raster/r.sun (ignored)
Compilation error in module: src.contrib/GMSL/g3d/src3d/sites/s.vol.rst
(ignored
Thanks for your help.  If you'd like to try to work through these
errors, let me know.
Take care,
Andy
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020911/d2f01387/config.log.gz
On Tuesday, Sep 10, 2002, at 15:14 US/Central, Glynn Clements wrote:
> andy agena wrote:
>> I've attached my config.log for the PostgreSQL error, as it seems that
>> there's a bunch of errors releated to it.
> /usr/local/pgsql/include/postgres.h:48:24: utils/elog.h: No such file
> or directory
> /usr/local/pgsql/include/postgres.h:49:26: utils/palloc.h: No such
> file or directory
> You need to locate that "utils" directory, and add its parent
> directory the argument of --with-postgres-includes. Multiple
> directories can be specified, separated by spaces; you need to use
> quotes, e.g.
> --with-postgres-includes='/usr/local/pgsql/include
> /usr/local/pgsql/include/internal'
> OTOH, if you can't find any "utils" directory containing those files,
> have you installed a newer version of PostgreSQL over an older
> version?
> 6.5.3 includes postgres.h, but it also includes utils/elog.h and
> utils/palloc.h (the "utils" subdirectory is in the same directory as
> postgres.h).
> 7.x doesn't include postgres.h and doesn't include the subdirectory
> either.
> Glynn Clements <glynn.clements at virgin.net>
