[GRASS5] Re: pg grass darwin - working
andy agena
andya at mac.com
Wed Sep 11 17:31:49 EDT 2002
Hi Glynn:
I won't be able to try config/make/install until tomorrow with
--with-gdal, but I'll let you know how it goes.
I did try the 'gcc -E -dM foo.c', but the only output was '# 1
"foo.c"'. I'm not sure what your '-dM' tag was supposed to do and it
doesn't seem to be an option in my gcc, so I've included the options I
have for gcc (3.1) below.
this is the output from nm LIB.powerpc-apple-darwin6.0/libgeo.a; do I
just need to [somehow] get rid of the underscores before the ax, etc?:
<snip>
libgeo.a(vars.o):
00000050 C _ax
00000050 C _ay
00000050 C _bx
00000050 C _by
00000004 C _reg_cnt
00000050 C _residuals
00000008 C _rms
00000028 C _use
what do I need to do for this 'malloc.h' bug?
Thanks again for your time,
Andy
% ./gcc --help
Usage: gcc [options] file...
Options:
-pass-exit-codes Exit with highest error code from a phase
--help Display this information
--target-help Display target specific command line options
(Use '-v --help' to display command line options of sub-processes)
-dumpspecs Display all of the built in spec strings
-dumpversion Display the version of the compiler
-dumpmachine Display the compiler's target processor
-print-search-dirs Display the directories in the compiler's
search path
-print-libgcc-file-name Display the name of the compiler's companion
library
-print-file-name=<lib> Display the full path to library <lib>
-print-prog-name=<prog> Display the full path to compiler component
<prog>
-print-multi-directory Display the root directory for versions of
libgcc
-print-multi-lib Display the mapping between command line
options and
multiple library search directories
-Wa,<options> Pass comma-separated <options> on to the
assembler
-Wp,<options> Pass comma-separated <options> on to the
preprocessor
-Wl,<options> Pass comma-separated <options> on to the
linker
-Xlinker <arg> Pass <arg> on to the linker
-save-temps Do not delete intermediate files
-pipe Use pipes rather than intermediate files
-time Time the execution of each subprocess
-specs=<file> Override built-in specs with the contents of
<file>
-std=<standard> Assume that the input sources are for
<standard>
-B <directory> Add <directory> to the compiler's search
paths
-b <machine> Run gcc for target <machine>, if installed
-V <version> Run gcc version number <version>, if
installed
-v Display the programs invoked by the compiler
-### Like -v but options quoted and commands not
executed
-E Preprocess only; do not compile, assemble or
link
-S Compile only; do not assemble or link
-c Compile and assemble, but do not link
-o <file> Place the output into <file>
-x <language> Specify the language of the following input
files
Permissable languages include: c c++
assembler none
'none' means revert to the default behavior
of
guessing the language based on the file's
extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
passed on to the various sub-processes invoked by gcc. In order to
pass
other options on to these processes the -W<letter> options must be
used.
For bug reporting instructions, please see:
<URL:http://developer.apple.com/bugreporter>.
On Wednesday, Sep 11, 2002, at 14:29 US/Central, Glynn Clements wrote:
> [Note: lines which are indented with ": " are from your make.log file.]
> andy agena wrote:
>> Well, I have PostgreSQL 7.2.2 running with GRASS, though I'm not
>> really
>> sure why (well, I do need to add my grass user account to my
>> postgresql
>> group to use it, but g.*.pg's are now in my bin--g.select.pg only
>> squawks about me not being part of the proper group). I added the
>> quotes around postgres-includes two paths, but that's about it.
>> the only configure errors are:
>> Compilation error in module: src/libes/vect32/georef (ignored)
> : gcc
> -L/Users/andyagena/Desktop/grass-5_0_0_src_0/grass-5.0.0/src/libes/
> LIB.powerpc-apple-darwin6.0 -L/sw/lib -o
> /Users/andyagena/Desktop/grass-5_0_0_src_0/grass-5.0.0/dist.powerpc-
> apple-darwin6.0/etc/geo.point OBJ.powerpc-apple-darwin6.0/bin_point.o
> LIB.powerpc-apple-darwin6.0/libgeo.a -lgis -llock -lz
> : ld: Undefined symbols:
> : _ax
> : _ay
> : _bx
> : _by
> : _use
> I've seen this before; it may have been reported by yourself (the
> other plausible candidate is Jeshua Lacock; I'm not aware of any other
> MacOS X users). I'm not sure if it was solved, though.
> These symbols should be defined in vars.o, inside libgeo.a:
> $ nm LIB.i686-pc-linux-gnu/libgeo.a
> [snip]
> vars.o:
> 00000050 C ax
> 00000050 C ay
> 00000050 C bx
> 00000050 C by
> 00000004 C reg_cnt
> 00000050 C residuals
> 00000008 C rms
> 00000028 C use
>> Compilation error in module: src/display/d.zoom (ignored)
> : gcc
> -I/Users/andyagena/Desktop/grass-5_0_0_src_0/grass-5.0.0/src/include
> -g -O2 -I/sw/include -c set.c -o OBJ.powerpc-apple-darwin6.0/set.o
> : set.c:11: conflicting types for `round'
> : /usr/include/architecture/ppc/math.h:274: previous declaration of
> `round'
>> Compilation error in module: src/imagery/i.pca (ignored)
> : gcc
> -g -O2 -I/sw/include -c main.c -o
> OBJ.powerpc-apple-darwin6.0/main.o
> : main.c:343: conflicting types for `round'
> `round'
> A similar error has recently been reported for the latest version of
> Cygwin.
> Check whether your version of gcc has an option to disable C9X
> features. C9X adds several new functions to existing ANSI C headers;
> this causes problems for existing code which already uses those names
> for something else.
> Ultimately, GRASS will need to become C9X compatible rather quickly.
> It seems that the gcc developers have caught "free software
> developers' disease" (i.e. "anything more than three months old is
> obsolete, and no longer supported; all existing code must be upgraded
> accordingly").
>> Compilation error in module: src/raster/r.in.gdal (ignored)
> : gcc
> apple-darwin6.0/etc/bin/cmd/r.in.gdal
> OBJ.powerpc-apple-darwin6.0/gbgetsymbol.o
> OBJ.powerpc-apple-darwin6.0/gdalbridge.o
> OBJ.powerpc-apple-darwin6.0/make_loc.o \
> : -ldl -lgis -lI -lproj -lz
> : _GBGetSymbol
> This is defined in src/raster/r.in.gdal/gbgetsymbol.c. There are two
> implementations:
> 1. The Unix dlopen/dlsym version, which is conditionalised upon:
> #if defined(__unix) || defined(__unix__)
> 2. The Windows LoadLibrary/GetProcAddress version, which is
> #ifdef _WIN32
> Presumably your gcc defines neither __unix nor __unix__; do you have
> any idea what it does define? Try "gcc -E -dM foo.c", where foo.c is
> an empty file.
> Also, you could try linking directly against GDAL, instead of using
> the "bridge" (dynamic loading) code, by using the --with-gdal
> configure switch.
>> Compilation error in module: src/raster/r.sun (ignored)
> : gcc
> : main.c:46: header file 'malloc.h' not found
> This is a straight bug (probably from someone who learned to program
> with Borland C, where malloc() really is in "malloc.h"). According to
> ANSI, the correct header is <stdlib.h>.
>> src.contrib/GMSL/g3d/src3d/sites/s.vol.rst
>> (ignored
> gcc
> main.c:33: header file 'malloc.h' not found
> Ditto.
> Glynn Clements <glynn.clements at virgin.net>
