[GRASS5] [bug #1325] (grass) cant start grass5, seems some lib not compatible
Glynn Clements glynn.clements at virgin.net
Thu Sep 26 09:56:08 EDT 2002
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1325
> Subject: cant start grass5, seems some lib not compatible
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.0.0
> after install, i type grass5
> then it shows me:
> etc/lock: lib/libc.so.6 version "glibc_2.1.3" not find (required by ...)
> root is currently running grass5. concurrent use is not allowed.
> and then seems the process is over, return me to command status. And
> i can't see any prompt about location or mapset.
> what's the matter?
It appears that the precompiled binaries aren't compatible with your
particular Linux distribution.
Glynn Clements <glynn.clements at virgin.net>
