[GRASS5] 5.1: Makefile question
Markus Neteler
neteler at itc.it
Wed Apr 2 03:53:44 EST 2003
On Wed, Apr 02, 2003 at 09:01:25AM +0200, Stephan Holl wrote:
> At Tue, 1 Apr 2003 16:01:03 +0200 Markus Neteler wrote:
> Hello Markus,
> > PROGRAMS = db.columns db.copy db.createdb db.dropdb db.droptable
> > allhtml:
> > for pgm in $(PROGRAMS) ; do \
> > cat $$pgm.html >> $$pgm.tmp ; \
> > done
> works well here, but I had to remove "html" in line 29 to compile
> proberly. all html-docs are created and copied to the right place.
Yes and no: Please check if the "DESCRIPTION" section was added to
the db.*.html pages. I am sure that this section is missing.
The same applies for g.rename, g.remove, g.copy, g.list in
src/general/manage/Makefile
No Makefile expert here...? I guess that this rule must be completely
rewritten, using $< $@ etc.
Markus
