[GRASS5] [bug #1784] (grass) grass_r_interface.html corrections
Bernhard Reiter bernhard at intevation.de
Mon Apr 7 04:40:06 EDT 2003
Hamish,
you do have CVS write access, don't you?
If it is a clear bug you can fix it in the CVS directly.
	Bernhard
On Mon, Apr 07, 2003 at 10:16:34AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1784
> I found the following problems in grass_r_interface.html ... have fun
> Hamish
> --- grass_r_interface.html.OLD	Mon Apr  7 18:40:13 2003
> +++ grass_r_interface.html	Mon Apr  7 20:05:23 2003
> @@ -209,7 +209,8 @@
>  map!
>  <p>After loading a map, first we can test if any NA raster cells are present
> -in the map (example: slope map):
> +in the map (example: slope map <a href="#genSlope">from below</a>):<BR>
