[GRASS5] Mac OS X Tcl fix and Startup Errors
Glynn Clements
glynn.clements at virgin.net
Tue Apr 8 08:59:20 EDT 2003
Jeshua Lacock wrote:
> Mac OS X allows the use of special/reserved characters in file names
> such as the exclamation mark ("!") and the space character (" ").
> This was causing gis_set.tcl and other Tcl scripts to choke using the
> native Aqua Tcl/Tk interface when encountering a file with illegal unix
> characters.
> It turns out the most elegant solution I could come up with was to
> create a wrapper for the "ls" command to escape the exclamation marks
> and to wrap the filename in quotes to compensate for spaces and other
> special characters.
> The wrapper is a shell script using awk and sed, and then I simply
> changed occurrences of "ls -a" with "lsWrap -a" and so on. I can supply
> patches if anyone is interested.
A better fix would be to just not use "ls", but to implement the
functionality in Tcl, using the "glob" command.
> I am also trying to fix these errors:
> Starting GRASS ...
> : command not foundtc/Init.sh:
> These errors are being caused by:
> puts stdout "GISDBASE='$database'; export GISDBASE;"
> puts stdout "LOCATION_NAME='$location'; export LOCATION_NAME;"
> puts stdout "MAPSET='$mapset'; export MAPSET;"
Do you have any idea how is this code causing the above errors? I'm
not doubting that it is, but I can't see any possible mechanism.
> If I change stdout to stderr, everything looks normal:
> set GISDBASE='/Users/jeshua'; export GISDBASE;
The strings aren't meant to be displayed on the terminal; they're
meant to be interpreted by Init.sh. Using stderr won't work.
> I don't get any errors when I remove the export part such as:
> puts stdout "GISDBASE='$database'"
The export commands are unnecessary. So are the settings for GISDBASE
and MAPSET; only LOCATION_NAME (and the OLD_* variables a bit lower
down) are actually used by Init.sh.
> If I include the semicolon, I get the error:
> I suppose this is a bug with the Aqua port of Tcl/Tk 8.4.2.
Or with the Mac's /bin/sh. In any case, you can remove the semicolon
and the export statement.
> What is the grass tcltk script trying to accomplish here? Just setting
> the environment variables and exporting them?
It's returning the data back to the Init.sh script:
case "$GRASS_GUI" in
# Check for text interface
[snip]
# Check for tcltk interface
tcltk)
eval `$WISH -file $TCLTKGRASSBASE/script/gis_set.tcl`
case $? in
1)
# The gis_set.tcl script printed an error message so wait
# for user to read it
echo "Error in Tcl/Tk startup. If necessary, please"
echo "report this error to the Grass developers."
echo "Switching to text mode now."
echo "Hit RETURN to continue..."
read ans
[snip]
0)
# These checks should not be necessary with real init stuff
if [ "$LOCATION_NAME" = "##NONE##" ] ; then
$ETC/set_data
if [ $? != 0 ]; then
echo "GISDBASE: $OLD_DB" > $GISRC
echo "LOCATION_NAME: $OLD_LOC" >> $GISRC
echo "MAPSET: $OLD_MAP" >> $GISRC
exit
fi
fi
if [ "$LOCATION_NAME" = "##ERROR##" ] ; then
echo "The selected location is not a valid GRASS location"
exit
fi
echo "ERROR: Invalid return code from gis_set.tcl."
echo "Please advise GRASS developers of this error."
esac
gis_set.tcl is meant to write some Bourne shell code to stdout, which
Init.sh then evaluates via a combination of backquotes ( `...` ) and
the "eval" command. Backquotes only capture stdout, not stderr.
> Also I am getting:
> Welcome to GRASS 5.0.1 (January 2003)
> The 'gis_set' result is 127. Everything seems to work fine, do you
> think the error is anything to be concerned about?
Maybe; anything other than zero normally indicates some type of error.
Init.sh should probably treat everything other than zero as an error
(i.e. use text mode instead; it certainly shouldn't just carry on
regardless). Of course, this would force you to fix whatever is
causing gis_set.tcl to return a non-zero exit code.
BTW, programs should avoid using code 127, as this is what system()
returns if it fails to execute /bin/sh; normally, system() returns the
program's exit code.
Glynn Clements <glynn.clements at virgin.net>
