[GRASS5] GRASS 5.0.2 released
Glynn Clements
glynn.clements at virgin.net
Fri Apr 11 14:30:12 EDT 2003
Markus Neteler wrote:
> > However, I can't use arrow keys in the interactive session. Is this normal
> > ? (I don't know r.mapcalc that well).
> AFAIK this only works if GRASS was compiled with readline support
> (which I didn't specify, should I?).
No; that would result in an r.mapcalc binary that only works if you
have the correct version of libreadline.
Glynn Clements <glynn.clements at virgin.net>
