[GRASS5] Re: [GRASSLIST:6033] Re: Why grass5 process alive.
Glynn Clements glynn.clements at virgin.net
Sat Apr 12 05:52:20 EDT 2003
H Bowman wrote:
> > First quit TCLTKGRASS; this ends only the graphical user
> > interface and (if you so request) closes the monitors. Then
> > type "exit" at the GRASS prompt to exit GRASS, thus,
> > GRASS> exit
> should the main exit cleanup script "killall tcltkgrass"
No, although saving the tcltkgrass PID and killing the specific
process might be worthwhile.
However, the original issue is the reverse: should quitting tcltkgrass
terminate GRASS? Certainly, that should only be done if tcltkgrass was
run automatically from the grass5 script, not if the user started it
manually from the shell.
> &/or open monitors?
Maybe.
Glynn Clements <glynn.clements at virgin.net>
