[GRASS5] ps.map: colortable control of categorical vs continuous
John Harrop
johnh at sjgeophysics.com
Thu Apr 17 21:12:04 EDT 2003
We are finding that with floating point tables we would like to use a
mixture of categorical and continuous colortables. The current 5.0 code
picks one or the other based on raster map type, although it seems that
the categorical table processing is quite happy with floats as well as
integers.
Perhaps it would be better to base the choice on two tests.
1) If the number of categories is > 0 (for int or float raster) then use
the categorical style by default.
2) Add an over-ride parameter to the colortable block that would force a
continuous style colortable even if categories are defined.
Cheers,
John Harrop
