[GRASS5] r.in.gdal updates?
Markus Neteler
neteler at itc.it
Fri Apr 18 06:04:30 EDT 2003
On Fri, Apr 18, 2003 at 12:15:57AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > PS: I have used cvs diff to create the file, hopefully in the right way.
> Use either "diff -u" (unified) or "diff -c" (context).
> Those formats include some context (lines before and after those being
> added/removed/modified), which makes them more robust. They are also
> easier to read.
> Patches which use the default format are only safe to apply to the
> exact code which was used for creating them. Applying them to code
> which has changed in any way is unreliable (patching may fail
> unnecessarily) and risky (patching may appear to succeed but produce
> the wrong result).
Thanks for the recommendations! Again the patch, now unified.
Markus
@@ -553,6 +553,7 @@
char msg[100];
char outputReal[200], outputImg[200];
char *nullFlags = NULL;
+ int (*raster_open_new_func)(char *, RASTER_MAP_TYPE) = G_open_raster_new;
/* Select a cell type for the new cell. */
@@ -567,19 +568,28 @@
complex = FALSE;
break;
- case GDT_CInt16:
- case GDT_CInt32:
- case GDT_CFloat32:
- case GDT_CFloat64:
- data_type = FCELL_TYPE;
- eGDT = GDT_CFloat32;
- complex = TRUE;
- break;
+ case GDT_Byte:
+ data_type = CELL_TYPE;
+ eGDT = GDT_Int32;
+ complex = FALSE;
+ G_set_cell_format(0);
+ raster_open_new_func = G_open_raster_new_uncompressed;
+ break;
+ case GDT_Int16:
+ case GDT_UInt16:
+ eGDT = GDT_Int32;
+ complex = FALSE;
+ G_set_cell_format(1);
+ break;
default:
eGDT = GDT_Int32;
complex = FALSE;
+ G_set_cell_format(3);
break;
@@ -592,7 +602,7 @@
if( complex )
sprintf( outputReal, "%s.real", output);
- cfR = G_open_raster_new((char *)outputReal, data_type);
+ cfR = (*raster_open_new_func)((char *)outputReal, data_type);
if (cfR < 0)
sprintf (msg, "unable to create raster map %s", outputReal);
@@ -601,7 +611,7 @@
sprintf( outputImg, "%s.imaginary", output);
- cfI = G_open_raster_new((char *)outputImg, data_type);
+ cfI = (*raster_open_new_func)((char *)outputImg, data_type);
if (cfI < 0)
sprintf (msg, "unable to create raster map %s", outputImg);
@@ -621,7 +631,7 @@
else
- cf = G_open_raster_new((char *)output, data_type);
+ cf = (*raster_open_new_func)((char *)output, data_type);
if (cf < 0)
sprintf (msg, "unable to create raster map %s", output);
