[GRASS5] [bug #1810] (grass) v.digit module, nviz
Request Tracker grass-bugs at intevation.de
Mon Apr 21 10:57:21 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1810
Subject: v.digit module, nviz
Platform: other
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.02
Hallo I am Ingo Dickel
from Munich (Germany),
 i have self compiled the version 5.02 of Grass.
My Linux System is Suse Linux 8.2. My hope was that i can start nviz
with the new support for tcl/tk 8.4. But there was no way.
The error lines from Nviz Version: @(#) 5.0.2 (April 2003)was:
**toplevel made
**child killed: segmentation violation
**    while executing
**"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f **/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=grund -name NVIZ **>&@stdout"
**    ("eval" body line 1)
**    invoked from within
**"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f **$env(GISBASE)/etc/nviz2.2/scri            pts/nviz2.2_script $argv -name **NVIZ >&@stdout"
**"if {$argv == ""} {
**#no arguments
**eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f **$env(GISBASE)/etc/nviz2.2/scrip            ts/nviz2.2_script -name NVIZ **>&@stdo..."
**    (file "/usr/local/grass5/bin/nviz" line 16)
Later i try to test v.digit
| GRASS-DIGIT Modified  4.10                                       Main menu  |
| MAP INFORMATION                                | AMOUNT DIGITIZED           |
|   Name:         Convex hull map                |   # Lines:         0       |
|   Scale:        2400                           |   # Area edges:    1       |
|   Person:                                      |   # Sites:         0       |
|   Dig. Thresh.: 0.0300 in.                     | - - - - - - - - - - - - - -|
|   Map Thresh.:  1.8288 meters                  |   Total points:    24      |
| OPTIONS:                                       |                            |
|     Digitizer:     Disabled                    |                            |
| Digitize  Edit  Label  Customize  Toolbox  Window  Help  Zoom  Quit  *  !  ^|
|GLOBAL MENU: Press first letter of desired command. [Upper Case Only]        |
but in this dialog above is no key going.
So i was a little bit frustrated. It was enogh to do become the compile
running. Maybe i have make an mistake.
I load the newest binarys on my Computer and install it.
But i have the exact same problems.
I think about to change the distrubition of my Linux System,
but maybe you can help me.
Thank's so lot !
IWDickel at genion.de
-------------------------------------------- Managed by Request Tracker
