[GRASS5] [bug #1827] (grass) cannot open shared file (using grass5 that was O.K.)
Glynn Clements glynn.clements at virgin.net
Mon Apr 28 13:05:21 EDT 2003
Request Tracker wrote:
> Grass5.1  started
> but shows an error that I do not understand
> GRASS 5.1.0-cvs:~/grass5.1 > d.m &
> [1] 19644
> GRASS 5.1.0-cvs:~/grass5.1 > Error in startup script: ps.map: error while loading shared libraries: libpq.so.2: cannot open shared object file: No such file or directory
libpq is the PostgreSQL client library; it has to be present in order
to use GRASS 5.1.
Glynn Clements <glynn.clements at virgin.net>
