[GRASS5] Problem compiling Grass51
Markus Neteler neteler at itc.it
Tue Apr 29 11:43:08 EDT 2003
On Tue, Apr 29, 2003 at 04:18:17PM +0100, Paul Kelly wrote:
> On Tue, 29 Apr 2003, Markus Neteler wrote:
> > right now (before reading this mail) I have submitted the dependencies for
> > all LIBs. The next changes I would leave to an expert - as I don't know too
> > much about Makefiles. On my Linux boxes it works well, but I have neither
> > access to SGI nor Solaris to try there.
> I don't see how d.where could compile anywhere the way it currently is (I
> presume Bob is using Linux as well?) As I understand it the dependency has
OK, after a clean it also doesn't compile here any more.
> to be an actual file or list of files that make can check to see when they
> were last modified. The dependencies follow a colon on the makefile. And
> underneath that are instructions for compiling the output program.
> Before fixing it we have to know why it is done like that, with the full
> pathname of the static library. Why not do it like GPROJLIB = -lproj,
> GISLIB = -lgis etc. in GRASS 5.0. Neater looking and makes it possible to
> use shared libraries.
Probably yes: But -lgrass_gis may be better to avoid conflicts with -ledit
etc. (so -lgrass_edit).
> I will make a start (see below). It can be an occasional series...
> make[2]: Entering
> directory `/indigo-disk2/grass/grass51/lib/form' cc
> -L/indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib
> -L/indigo-disk2/grass/doom.ee.qub.ac.uk/lib -o
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/etc/form/form
> OBJ.mips-sgi-irix6.2/form.o
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib/libgrass_dbmi.a
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib/libgrass_gis.a
> -L/indigo-disk2/grass/doom.ee.qub.ac.uk/lib -ltk -lm -ltcl -lm \
>                          -lm -lz
> /indigo-disk2/grass/doom.ee.qub.ac.uk/lib/libsnprintf.a ld: WARNING 84:
> /indigo-disk2/grass/doom.ee.qub.ac.uk/lib/libz.a is not used for resolving
> any symbol. ld: ERROR 33: Unresolved text symbol "G_setenv2" -- 1st
> referenced by
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib/libgrass_dbmi.a(connect.o).
> ld: ERROR 33: Unresolved text symbol "G__getenv2" -- 1st referenced by
> ld: INFO 152: Output file removed because of error. make[2]: ***
> [/indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/etc/form/form] Error 1
> make[2]: Leaving directory `/indigo-disk2/grass/grass51/lib/form' make[1]:
> *** [subdirs] Error 1 make[1]: Leaving directory
> `/indigo-disk2/grass/grass51/lib' make: *** [default] Error 1
I have found that
#include "gis.h"
was missing in
./lib/vector/Vlib/field.c
(submitted to CVS). Does this help?
Markus
