[GRASS5] Problem compiling Grass51
Radim Blazek
blazek at itc.it
Wed Apr 30 04:30:49 EDT 2003
On Tuesday 29 April 2003 05:18 pm, Paul Kelly wrote:
> I will make a start (see below). It can be an occasional series...
> make[2]: Entering
> directory `/indigo-disk2/grass/grass51/lib/form' cc
> -L/indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib
> -L/indigo-disk2/grass/doom.ee.qub.ac.uk/lib -o
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/etc/form/form
> OBJ.mips-sgi-irix6.2/form.o
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib/libgrass_dbmi.a
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib/libgrass_gis.a
> -L/indigo-disk2/grass/doom.ee.qub.ac.uk/lib -ltk -lm -ltcl -lm \
> -lm -lz
> /indigo-disk2/grass/doom.ee.qub.ac.uk/lib/libsnprintf.a ld: WARNING 84:
> /indigo-disk2/grass/doom.ee.qub.ac.uk/lib/libz.a is not used for resolving
> any symbol. ld: ERROR 33: Unresolved text symbol "G_setenv2" -- 1st
> referenced by
> /indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/lib/libgrass_dbmi.a(conne
>ct.o). ld: ERROR 33: Unresolved text symbol "G__getenv2" -- 1st referenced
> by
>ct.o). ld: INFO 152: Output file removed because of error. make[2]: ***
> [/indigo-disk2/grass/grass51/dist.mips-sgi-irix6.2/etc/form/form] Error 1
> make[2]: Leaving directory `/indigo-disk2/grass/grass51/lib/form' make[1]:
> *** [subdirs] Error 1 make[1]: Leaving directory
> `/indigo-disk2/grass/grass51/lib' make: *** [default] Error 1
Are there G_setenv2/G__getenv2 realy available in libgrass_gis.a
(nm libgrass_gis.a)?
Radim
