[GRASS5] [bug #2057] (grass) fix configure test for blas/lapack libraries on Mac OS X
Request Tracker grass-bugs at intevation.de
Tue Aug 12 10:45:07 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2057
Subject: fix configure test for blas/lapack libraries on Mac OS X
Platform: other
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: all
in Mac OS X, the blas and lapack library functionality in included in the vecLib framework (they
are both in the same framework).  So configure needs to check for '-framework vecLib' for the
blas and lapack libs if the user wants those.
No change is needed for the headers referenced in the source code.
- William Kyngesburye
-------------------------------------------- Managed by Request Tracker
