[GRASS5] [bug #2061] (grass) r.los needs FP update
Glynn Clements
glynn.clements at virgin.net
Wed Aug 13 11:27:52 EDT 2003
Request Tracker wrote:
> Subject: r.los needs FP update
> grass binary for platform: Compiled from Sources
> After inspection of the source code (due to unsatisfying results)
> it seems that 'r.los' only works with CELL elevation data:
> src/raster/r.los/cmd/main.c:
> /* allocate buffer space for row-io to layer */
> cell = G_allocate_cell_buf();
> /* open elevation overlay file for reading */
> old = G_open_cell_old (elev_layer, old_mapset);
> etc.
> The module should be fixed to also accept FCELL/DCELL DEMs.
> However, I have no clear idea how much work is needed for
> that as segmentation is used internally.
It should probably be changed to just use either FCELL or DCELL
internally. I don't see any reason to preserve the underlying data
type.
AFAICT, the only situations where CELL maps shouldn't be converted to
FP is where they may actually represent discrete categories rather
than a scalar quantity.
Glynn Clements <glynn.clements at virgin.net>
