[GRASS5] Preparing 5.0.3 release
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Aug 20 06:21:06 EDT 2003
On Wed, 20 Aug 2003, Markus Neteler wrote:
> Hi,
> I have sync'ed *some* bugfixes from CVS HEAD into the 5.0.3 release
> branch (so no NVIZ changes, no PROJ changes as they'll go into 5.3.0).
> Some questions remain:
> - what to do with all changes/updates in
> src.garden/grass.postgresql
> (*.pg modules)
> - what about the ps.map changes?
> - IL_create_bitmask() change (rst lib and related modules) ?
This was so these modules would honour the MASK in force as well as using
a mask set by the 'maskmap' command-line paramter. It could be considered
a bugfix but I suppose it changes the functionality slightly so maybe it
should wait.
I think r.resamp.rst should be re-enabled in the compilation list as I
fixed a major null handling-related bug in it.
> - r.transect changes?
> - s.surf.idw sites index?
This is not a bugfix and should not change the output of the command, so
there shouldn't be a problem, but it is a major change so it should wait.
Those are the ones I had a hand in
Paul
