[GRASS5] Roadmap: Numbering
Bernhard Reiter
bernhard at intevation.de
Fri Aug 22 10:40:21 EDT 2003
On Thu, Aug 14, 2003 at 12:12:23PM +0200, Markus Neteler wrote:
> On Thu, Aug 14, 2003 at 11:05:13AM +0100, Paul Kelly wrote:
> > On Thu, 14 Aug 2003, Markus Neteler wrote:
> > > Are there implications to release 5.3.0 before 5.0.3?
> > Only that people might use it :) I think the CVS HEAD is in good working
> > order at the minute. The old experimental releases 5.0.0preX had some
> > quite serious bugs in them and at that time there was no alternative
> > stable release available; I think the time is right to release 5.3.0.
> To somewhat confirm:
> I have looks at the diffs between the 5.0.x release branch and the
> CVS HEAD. It seems to be a lot of (useless?) work required to
> patch in the important bugfixes into the release branch for a 5.0.3
> version.
> Probably we better work on 5.4.0 then and 5.7.
5.0.3 is important for stability reasons.
In other projects I know how important that is in principle.
It will be quite some time before 5.4.0
and we need an official most stable version until we get this.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030822/f8db20a1/attachment.bin
