5.0.3 release candidate 1 - was: Re: [GRASS5] Roadmap:
Numbering
Stephan Holl
sholl at gmx.net
Sun Aug 24 14:25:25 EDT 2003
Hello Markus,
At Sun, 24 Aug 2003 18:51:49 +0200 Markus Neteler wrote:
> OK, fixed in CVS (release branch). The patch is
> diff -u -r1.4.2.3 main.c
> --- main.c 20 Aug 2003 08:16:03 -0000 1.4.2.3
> +++ main.c 24 Aug 2003 16:47:26 -0000
> @@ -47,14 +47,14 @@
> opt1 = G_define_option() ;
> opt1->key = "bcolor" ;
> opt1->type = TYPE_STRING ;
> - opt1->answer = DEFAULT_BG_COLOR ;
> + opt1->answer = "black" ;
> opt1->required = NO ;
> opt1->description= "Color used for the background, or
> \"none\"" ;
> opt2 = G_define_option() ;
> opt2->key = "tcolor" ;
> opt2->type = TYPE_STRING ;
> - opt2->answer = DEFAULT_FG_COLOR ;
> + opt2->answer = "white" ;
> opt2->required = NO ;
> opt2->options = D_color_list();
> opt2->description= "Color used for the text" ;
thanks, compiles now!
> > after a quick test
> > * NVIZ is up and running,
> Great. But you tested with tcl8.3.
> Is there anyone with tcl8.4 who could try?
I recompiled with tcl8.4,
* tcltkgrass runs,
* NVIZ stops running,
The papers are available at
http://www2.gis.uiuc.edu:2280/modviz/
Loading Data
Update elev null mask
Loading Data
translating colors
Adding panels from
/home/steph/grass-5.0.3rc1/dist.i686-pc-linux-gnu/etc/nviz2.2/scripts
the "please wait"-boxes appear, and the above message is the last output
of NVIZ.
ps ax shows a defunct-process for NVIZ.
any suggestions?
cheers
Stephan
Stephan Holl
GnuPG Key-ID: 11946A09
20:21:03 up 9:07, 1 user, load average: 0.34, 0.13, 0.19
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030824/84d3edae/attachment.bin
