[GRASS5] Re: Mars planet location
Alessandro Frigeri
geoalf at libero.it
Mon Aug 25 13:53:43 EDT 2003
Hello Paul and Markus,
The importance for using a 0-360 degrees system for Mars comes form
international research institutions' recommendations from the 1970's.
The 'strange thing' is that there are two recommended systems, but now
it seems that data will be produced according to one of
them.
Here you are the suggested coordinate systems for Mars formalized in
the 1971 International Astronomical Union meeting:
Planetocentric Coordinates (east/'ocentric):
Longitude is measured positive eastward and latitude is planetocentric
defined as the angle between equatorial plane and a line from the
center of the body to a given point
Planetographic Coordinates (west/'ographic):
Longitude is measured positive westward (direction opposite to the
planetary rotation) and latitude is defined as the angle between the
equatorial plane and the normal to a spheroidal reference surface on
the given point.
The Planetographic Coordinates were used for products from 1970's
through 1990's.
Mars Global Surveyor's Mars Orbiter Laser Altimeter team adopted the
right-handed Planetocentric system.
Also NASA's Odissey and ESA's Mars Express High Resolution Stereo
Camera experiment are using Planetocentric system.
So it seems that while there are two 'official' systems, the
east/'ocentric is beign adopted for latest data.
Grass longitude 'Terrestrial' system is also right-handled (if we think
to it as -180 0 +180) but giving a full 0-360 extent will allow to skip
coordinate tranlsation during import phase of data.
Other 'Terrestrial' GIS used for planetology simply use -+180 long
system. As far as I know, only specific Planetology (Spectrometer and
Image Analysis) tools at the moment support the full 0-360 system.
Projected Mars data is furnished mainly in Simple Cylindrical (Plate
Caree) projection with auxiliary files or headers providing the long
system used and ellipsoidal parameters used in projection. There are
several dataproducts that use different ellipsoidal parameter for data
projection.
Another issue to take care of is, in my opinion, that if we use
planetocentric coordinate system, latitude has to be considered
'geocentric' and not geographic/geodetic (see above). If we have a
sphere the two systems coincide, but if we use an ellipsoid, we will
get two different latitudes ('centric & 'graphic) for a given point
(the maximum difference is at about 45 degrees). Anyway, I never seen
Mars's dataproduct in planetocentric system projected on an flattened
ellipsoid.
In my experience I've only processed data in planetocentric system
projected in Simple Cylindrical proj over a Sphere (latest data) and
data coming in Simple Cylindrical projection with planetographic system
over a flattened ellipsoid (older data).
I hope this will be useful.
Cheers
Alessandro
On 2003.08.24 21:09, Paul Kelly wrote:
> Hello Markus
> Markus Neteler wrote:
> > thinking again about the Mars coordinate system, I found that
> > PROJ4 support such shifts (guess you know that already):
> > cs2cs +proj=latlong +to +proj=latlong +pm=-180
> > 180W 0N
> > 0dE 0dN 0.000
> > 0E 0N
> > 180dE 0dN 0.000
> > 180E 0N
> > 360dE 0dN 0.000
> > 100E 0N
> > 280dE 0dN 0.000
> > Could we make somewhat use of the prime meridian do support the Mars
> > coordinate system (probably still changes are needed for the global
> > wrap around)?
> I thought a little bit about this and as far as I can see that will
> not
> be any help as the main problem (apart from perhaps georeferenced data
> i/o operations) is just presenting the range of longitudes to the user
> as 0 to 360 instead of -180 to +180. Internally to GRASS the data
> could
> still be stored as it is now. Perhaps this would be as simple as
> changing the G_scan_{easting,northing} and G_format_{easting,
> northing}
> to accept a parameter flag that would indicate if longitude values
> should be interpreted in the 0 to 360 or -180 to +180 system. But it
> is
> sure to turn up other places that would need to be changed (maybe bugs
> that should use these functions but don't).
> We would be best to look at as well how it is handled by other
> software.
> It doesn't seem to be a very important problem to me as it doesn't
> affect GRASS' analysis capabilities (it is only an aesthetic thing)
> but
> I don't think I completely understand why it is important for Mars.
> Paul
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Alessandro Frigeri
echo '>ti.orebil at flaoeg<' | rev
