[GRASS5] [bug #2238] (grass) r.series: support for wildcards
	in input filenames
    Glynn Clements
    glynn.clements at virgin.net
    Tue Dec  2 11:12:56 EST 2003
Huddleston, John wrote:
> The g.parser usage is <filename> [<argument> ...]
> For it to be changed the logic would be to loop through the arguments
> until a non-file name occurs.   Logic would have to be added to see if
> any arguments remain.    If this is acceptable design, I can add the code.
Sorry, I don't understand what you're saying.
What I was suggesting was basically:
1. Add an additional type, for use in the "type" field of
"struct Option", e.g. TYPE_FILENAME.
2. If an option had:
	opt->type == TYPE_FILENAME && opt->multiple
then G_parser() would do glob expansion, so in Hamish' example, using:
	input=insitu_data.*
would have the same result as:
	input=insitu_data.001,insitu_data.002,...,insitu_data.052
Glynn Clements <glynn.clements at virgin.net>
